disable snmp traps l3vpn
disable synmp traps l3vpn {vr vr_name}
Description
Use this command to turn off SNMP trap support for L3 VPN.
Syntax Description
vr_name Specifies the name of the parent VR where this RFC 4382 scalar is applied. If vr_name is not provided, then this command is applied to the VR in the current context.
Default
Enabled.
Usage Guidelines
Use this command to disable L3VPN SNMP traps.
The following example disables L3 VPN SNMP traps support on the switch:
disable snmp traps l3vpn vr vr-default
This command was first available in ExtremeXOS 15.3.
Platform Availability
